problem changing spark plugs
im doing the passenger side bank (U.S)
eventually got that rubber shield out....what a pain.
disconnected all the vacuum and coolant lines.
unplugged the coil plugs.
disconnected the 4 wiring loom connectors at the front of the engine.
unclipped the 3 clips to move the wiring loom out of the way.
now is where the problem is, i cant move the wiring loom because
i think i need to remove the 3 injector wiring plugs, but they look very difficult to get to, and even more difficult to re-attach if im even able to get them off.
anyone run into this?....any advice on how to proceed?.... id hate to give up at this point but i also dont want to end up with a disabled car in the driveway, i already got the drivers side done.
thats all well and good but not all jaguar owners have jaguar wallets which is kinda the purpose of these various forums 😜
the XF, XE and F type share an engine but the videos showing XE and F type are different and much easier than the XF.
PAB.... let me know when you next need them done, i'll only charge $750😜😜😂😂
removing this piece is the key....it looks like a lot of work but it only involves removing 8 easy to access 10mm bolts.
(and 3 of those are the fuse box bolts which allows you to swing that out of the way too)
the benefit of this is method is the rubber/foam piece which is normally difficult to install, is really easy and just pops in place
