Problem with Jaguar XF draining the battery and alarm going on when parked
Hello,
I have 2011 Jag facelift version 2.2D. I noticed, that once in a while the alarm goes on automatically which eventually results in draining the battery.
I also noticed, that when parked, locked and sitting inside the car, the speedmeter and speed clock needle continues to drop from 0 down, then back to 0 and drops again. It also makes a ticking sound.
Also the warning light button blinks once in a while and the handbrake light on the shield.
Is this normal?
Can this drain the battery?
Can drained battery start an alarm?
Any advice would be extremely appreciated.
Is this normal?
Well if the battery is low you'd need to find out why? Bad alt, bad connections bad battery etc. but I would start with that, seen batteries bad off the store shelf. And pay no attention to dpk, he's the master of adding absolutely 0 to ANYTHING!
FS[MidAtlantic]: Jag tires like new
kenatofc
04-06-2016 11:26 AM
