Programming Garage Door Opener
#41
I had a 2012 XF with a genie opener (replaced new)
Make sure you follow all the steps from start to finish.
But my wife's 2011 Lexus needed the repater to work.
I think it mainly depends on your garage door opener.
#42
#43
Rome191, your detailed description is the best so far. UNFORTUNATELY for me, still not working....I am having issues in step #3:
"3. Press and hold the button you want to program and the button on your existing garage door opener's remote until the light starts flashing rapidly. Then release both buttons.
I AM NOT GETTING THE RAPID FLASH....AFTER SLOW FLASHING FOR ABOUT 40-50 SECONDS, THE LIGHT JUST TURNS OFF. AND WHEN I PUSH THE BUTTON TO SEE IF IT WAS PROGRAMMED, I JUST GET A SLOW FLASHING, SO CLEARLY NOT PROGRAMMED. ANY HELP?!?!?!
#44
#46
#47
i am not. Not sure what a repeater kit is! How do i get info on getting one? Thanks so much once again
#48
https://www.liftmaster.com/catalogre...structions.pdf
There is a website where you can put in details of your door opener and your car and it will you if they are compatible
Good luck. Worked like a charm with mine
#49
#50
#51
Both buttons pushed did successfully clear any previous codes which was indicated by a rapidly flashing light when pushed for nearly 20 seconds.
The mistake I was making was not pushing the "Program" button on the actual door opener itself after I had sync'd the remote to the rear view mirror receiver. I had to also do step 4&5 in the posted video.
99xk8guy
06-05-2023 06:28 AM
