Pulley changing Fun!
Oven works but do yourself favor a get a $20 torch so you can heat it up good right close to the car. If it cools before you get it all the way on, you'll be cutting the new one off too..LOL And be sure the SC shaft is polished up spotless for the install.
1st dyno run on the DynoDynamics 403HP at the wheels. - Bone Stock
Just put on full exhaust, sport cats, sport mufflers. Another dyno run June 23. we will see the benefit of exhaust.
Then....
1.5 pully and tune followed by another dyno pull to get the final numbers....
I'm hoping to get mine rerun Saturday. planning on getting there an hour early and cooling everything down first for a glory run. Lack of heat soak and the supercharger coolant pump working properly should give me the best realistic number for my car.
Looking to forward to seeing the exhaust numbers to see how much your work improved hp as I don't remember anyone doing just exhaust then dyno
rachelstr
09-03-2015 12:59 PM
