Pulley changing Fun!
Old 06-03-2015, 03:02 PM
Bigg Will's Avatar
Originally Posted by panels
Did you find that baking at 400 worked well to just slip it on?
Doing this next week....
Oven works but do yourself favor a get a $20 torch so you can heat it up good right close to the car. If it cools before you get it all the way on, you'll be cutting the new one off too..LOL And be sure the SC shaft is polished up spotless for the install.
Old 06-13-2015, 02:58 PM
Nooncat's Avatar
I might have missed this but has anyone been able to confirm horse power after the pulley and tune upgrade on a 4.2 s/c ?
Do you have to get the tune and if you do how high can you go? XFR hp for that model year?
Old 06-13-2015, 09:58 PM
panels's Avatar
I'll let you know in about two weeks. 5.0 Supercharged
1st dyno run on the DynoDynamics 403HP at the wheels. - Bone Stock
Just put on full exhaust, sport cats, sport mufflers. Another dyno run June 23. we will see the benefit of exhaust.
Then....
1.5 pully and tune followed by another dyno pull to get the final numbers....
Old 06-14-2015, 09:55 AM
2010 Kyanite XFR's Avatar
Default Pulley changing Fun!
I'm hoping to get mine rerun Saturday. planning on getting there an hour early and cooling everything down first for a glory run. Lack of heat soak and the supercharger coolant pump working properly should give me the best realistic number for my car.
Looking to forward to seeing the exhaust numbers to see how much your work improved hp as I don't remember anyone doing just exhaust then dyno
Scarecrow
03-28-2016 03:17 AM
Jeh
XJ40 ( XJ81 )
10-13-2015 09:23 PM
teacoff
09-10-2015 08:25 AM
rachelstr
09-03-2015 12:59 PM
d a
09-03-2015 02:34 AM
Quick Reply: Pulley changing Fun!
