Purge solenoid Issue? May be?
Hello fellow members,
I have a 2009 Jaguar XF Supercharged and I am running into a little bit of an issue with it. Every time I put fuel in, it has a hard time starting up. I could hear the starter trying to start it up but no luck in starting it. Then after a few tries, it fires up but with lots of hesitation.
I sometimes see a P0441 Evap Emission Control System Incorrect purge flow CEL. There were some vacuum leaks under the hood but my mechanic says they should be resolved and I have driven it for about 100 kms after that and no code yet.
Could this code be just because of the vacuum leak somewhere? I have been filling up jerrycan to fuel it up lately. I put gas in it at night and then its fine in the morning. Just a little scared to take it to a pump and fill it up in case it would not want to fire up again.
has anyone experienced anything like this before? I guess I gott take it to a gas station and try putting some gas in to see if the issue is gone or is it needs some new parts.
Strangely I have had this occur on my 2014 3.0SC after refuelling. It throws also some messages "pedestrian system failed" and the outside temperature reading goes to a crazy -40C degrees reading!! After finally starting it stays with this until the system shuts down and somehow resets itself after some hours. I was thinking also the purge valve or could it be the battery needing change.
ednedwards
22
03-04-2021 12:44 PM
