"Quickshift" transmission on XFR-S/F-Type vs XFR transmission
I'm seriously leaning towards picking up a 2013 XFR to be my new daily driver (Would love to get an XFR-S, but just can't justify the cost at this time). I have driven an F-Type V6 S and an XKR-S (but not an XFR-S), both of which I thought had excellent transmissions for being a paddle-shift (I'm a manual snob, but am becoming resigned to the fact that I'm likely going to have to bite the bullet at some point and accept paddles sooner or later).
The F-Type/XFR-s have the "Quickshift" transmission, whereas the XKR-S transmission while not officially being "Quickshift", I thought was plenty impressive. I have not driven a 2013 XFR, which technically does not have the "Quickshift" transmission of the F-Type or the XFR-S.
My question is this: I believe 2013 is the first year with the 8-speed ZF transmission on the XFRs. Anybody have any qualitative comments or observations on the XFR non-Quickshift transmission vs the F-Type/XFR-S? Would be curious to know how quick it is upon gear selection, ability to revmatch on downshifts, overrun/pop sounds from exhaust, etc. If it is similar to the non-quickshift XKR-S, i know I'd be happy with it, but just don't have a good idea without having driven it.
I know it would be a lot easier to just test drive it, but unfortunately my local dealer wouldn't let me test drive any of the brand new ones, and they didn't have any used 2013 XFRs back in inventory. Needless to say, the XKR-S I test drove was incredible.
Quickshift is software. The transmissions are all the same. The transmission shift program in my awd XF selects gears quite slowly while in D, presumably for fuel economy reasons. In S with Dynamic mode engaged the transmission seems pretty much the same as in the F Types I drove.
As a previously dedicated manual tranmission guy let me suggest you'll soon forget about shifting manually. I specfically test drove the XF to ensure it shifted manually as well as a true manual gearbox, and it does. After the first year I just stopped using the paddles except very occasionally. The automatic is just that good.
My XF-Supercharged was my first automatic car. I was a bit weary going to an automatic. The shifting is generally fantastic but it is software controlled and it isn't always perfect. In my experience the trans needs a minute or two to get up to temp but then it's nearly flawless. When it's cold I can feel harder/erratic shifts. It's fine if I baby it but I have had some very shocking experiences when going even slightly above 10% throttle (trans won't shift at all or clunks into gear to early). Been to the dealer a few times and they never find any issues. I don't believe my situation is necessarily normal but from what I read online a cold auto can have issues shifting. I don't drive my XF in the winter so I'd imagine that could highlight the issue. I have never had any MTX issues related to cold fluid unless the fluid is very cold (below -10F outside). I'm trying to point out that the OP should realize that the auto is different and it will take some getting used to.
Good luck with your purchase. I have never regretted getting my XF. You'll love whatever XF you pick up. If it were me I'd go with a 2012 XFR with a few miles on it to save a good chunk of change. Get a 2010 or 2011 XFR with low miles and you can save a boat-load.
I seem to recall you posting another comment stating these modern engines don't need much time to warm up so there is no cause for concern. Change your mind already?
You said the transmission takes only a minute or two to warm up. You say it is "shocking" when you've gone WOT on a cold transmission.
Ergo, since the engine takes more than a minute or two to warm up you must have used WOT on a stone cold engine.
If that is the case your issues will be with a worn engine, not a faulty transmission.
I am only reading what you wrote. Did you mean something different?
I've found that my new 8 speed tranny does shift much faster and smoother then my old six speed in my last SC. I tend to believe that the softwear is much better in my 2013 then it was in my SC. That being said: The two extra gears do nothing for speed but is geared more for gas savings. I have to admit that I love driving my 2013 XFR more then I did my XFSC. I think this because Jaguar has worked out alot of its bugs and better writen softwear. IMHO.
Your comments are not helpful or needed in this thread. I could argue a bit more but, based on past experience, I know you can never be proven wrong even when it's blatantly obvious. Keep your comments to yourself if you aren't going to be helpful. I was posting based on my experience so leave it at that.
The ZF transmission, one of the very best in the World, apparently only in your particular car, suffers from a very specific alleged defect in its 6 spd transmission, but only when cold and for a minute or two after start up, and only when using WOT, and this is worthy of communicating on a thread about the possible differences between the Quickshift 8 spd and the regular 8 spd?
Sorry I missed your point entirely.
Hmmm, a reminder first, this is not the place to have a go at each other, although clearly it is OK to state that someone disagrees/agrees with a statement. (we'll leave it at that)
I have no experience with the XF (sadly) but I have 35 years of driving 'auto-boxes'.
From my experience an auto box should ALWAYS be given time to warm up, before hammering it, idem an engine.
WOT with a cold trans or engine is a long term recipe for trouble and short term is likely to display 'odd' characteristics, that a dealer might not be able to replicate due to the car being up to temp when it gets there, or before they hammer it.
However this thread is not about this, but is asking for experiences with Quickshift/Non-Quickshift.
Please keep On Topic.
I have noticed the adaptive software in my XF 8 spd seems more aggressive than in my older 6 spd.
The Quickshift in the F Type and now in the XFR-S does hold the gears more aggressively if you lift off during a hard acceleration event, but now so does my car.
One nifty Quickshift feature I have not experienced yet in my XF is an automatic downshift while in Dynamic mode. That really is cool, the software recognizes you are driving aggressively and downshifts automatically as you brake hard for a corner. This is equivalent to an automatic heel and toe downshift in a manual gearbox. I was pleasantly surprised by this while test driving the F Type V6-S and have not yet experienced it in my XF so might be a Quickshift only feature. I was far too busy to notice this while test driving the F Type V8-S!
BTW, the XFR-S competes handily with BMW M5 for less money. Limited production though and quite expensive.
