Radar detector/ cigarette lighter question
Ok, for those this may help. I just finished this little project. I mounted my Audi Blendmount which works for the XFR along with their 12" Mirrortap for power. Remove the shell behind the mirror. Unplug the connector in order to handle it more easily. You will tap the black wire for ground. I did not have a brown/yellow like Chuck so I had to look for the switched power. It turned out to be the wire next and to the left of the black when the connector is plugged in. Sorry but I forgot to write down the color of the wire and realized it after all was put back together. In any case it took a couple of minutes to find it via trial and error. You can also try a voltmeter.
By the way, this is much easier and quicker than fiddling with the overhead console as long as you use one of these power tap-type wires.
Good luck!
Good luck!
Yeap, its their mount for Audi, aud-002/bbe-2025. Very thin at the mounting point.
jagent
09-12-2015 01:40 AM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
