Radiator fan not working - engine overheating
Hello,
i am currently on holiday in Austria and visited several garages to fix my little problem but no garage has eother time or knowledge to get it done. It seems many garages are affraid of jaguar somehow…
i would like a quick fix/workaround so i can go to
my garage in the Netherands next week. So i was thinking of connecting the radiator-temparaturenswitch wires so that the fan is always on adn i can drive home. It is just that the radiator is packed and i cannot reach it so then i was thinking maybe i can manipulate the relais in the fuse box so that it is always on. But i cannot find which relay is for the ventilator. There is no schema for the relays in the user manual only for the fuses.
does enyone know which relais is for the ventilator?
AlbertWeeda (08-23-2023)
Marcin Wasilewski
03-08-2023 04:14 PM
