Rattle from Trunk Lid
Recently, I started getting a rattle from the trunk lid, which sounds like something is hitting the trunk lid. I checked the trunk, and the battery and spare tire were both securely bolted down. I emptied the trunk of the warning triangle and large umbrella that I keep in there, but the rattle continues. I can't see the inside of the trunk lid because there's a panel covered with carpeting so there could be some wires in there and to remove the panel, one would have to remove the catch for the trunk lid and the pull-down for the trunk lid, which seems difficult. Any ideas?
I removed the trunk lid panel yesterday and wrapped cloth tape around all the wires that might contact the trunk lid and cause a rattle, but with little improvement. I was surprised by how many wires there were between the panel and the trunk lid. The hardest part of removing the panel was getting the emergency release handle off but the pictures helped. BTW, the pull-down handle is only attached to the panel, so when you remove the trunk panel, it comes down with the panel. The panel is attached to the trunk lid with plastic fasteners that look like Phillips screws but they're not screws at all.
Many thanks to fivel for the pictures!
I removed the spare tire and there's nothing there. I'll look in the bumper from underneath. You make a good point about something falling into a cavity in the trunk lid. I would have to remove the panel again. Also, what could have fallen into a cavity? Everything seemed in tact in the trunk lid. Thanks again.
