Read windows wont open
Rear windows wont open
Got the car back from the shop, had an exhaust leak. I don;t think they disconnected the battery, everything seems set correctly
Rear windows will not open, with driver's control pack or rear door buttons. I can see the yellow light turn on when I hit the safety button, but no dice on the rear windows with it on or off and not from the buttons back there either.
Thinking there may be a fuse for the rear windows only. can't track it down, any thoughts?
Looking for fuse box info ( and yes I searched so many conflicting things.
In the trunk is it the module fuse? I only see fuse 30 trunk driver's door module
On mine they are numbers 20 and 29 in the passenger fuse box. See owners manual for location
However two separate fuses for the switch packs on each door, so it seems unlikely to be that. I've rarely seen a fuse actually blow on a modern car
Sometimes modules can get stuck/ crash and lose functionality. That would be my guess. Can you get to the battery in the right hand side of the trunk? I'd suggest disconnecting it for about a minute and put it back on. See if that fixes it. You may need to reset the window stop limits, but that would be my starter as a fix
06-24-2011 12:55 PM
