Rear axle leak please help!
Old 09-04-2016 | 09:54 PM
nasa25's Avatar
Looks like my vin number is in the range provided above. Makes sense since my diff is eating pinion seals one after the other. It's strange that the dealer mentioned to me multiple times that all of the recall work on my car was done however I guess this is a tsb as opposed to a recall.
Anyone have luck getting an upgraded diff comp'd under this tsb?
Old 09-06-2016 | 08:58 PM
Quicktruck's Avatar
Banned
Hmmm, I had my rear axle seal repaired a few months ago. Do they work with us retroactively?
Old 09-07-2016 | 12:57 PM
brettzky13's Avatar
Good luck getting Jaguar to fix your rear diff. I was pretty much told to pound salt 10K Canadian fix to update to the redesign. I could NOT find a diff to fit this car ANYWHERE I even was calling shops over in UK nodda! No aftermarket stuff, no re built stuff and any shops I called about used parts said these things don't last an hour on their shelf.
Old 09-07-2016 | 01:11 PM
Quicktruck's Avatar
Banned
My seal was repaired by a local mechanic who was not affiliated with Jaguar. He was able to get the parts and do the repair no problem.
Old 09-07-2016 | 01:41 PM
nasa25's Avatar
Thanks for the update. So what did you wind up doing? I've been discussing the issue with a local Jag mechanic. He told me that one of his customers got Jag Canada to comp a new diff after TONS of complaining.
Mine goes in for new seals tomorrow. I'll hold out as long as I can just replacing seals while looking for a post R41865 diff from a wreck.
Old 09-07-2016 | 02:15 PM
Quicktruck's Avatar
Banned
My local non-Jaguar mechanic replaced the seal and refilled the axle area for $325 - not bad by my figuring.
Old 09-07-2016 | 02:41 PM
nasa25's Avatar
That's basically what I'll be paying. $320 incl tax. I'm curious to see how long it lasts. I believe they are replacing the output shaft seal. A couple years ago I did both the output shaft and pinion seal. Seems like the pinion seal has held up (I recall my mechanic replacing it last time just because he had everything apart).
  #28
Old 11-08-2016 | 09:49 AM
nasa25's Avatar
well there's bearing play on my passenger side shaft. Replaced that seal 6 weeks ago and there's another leak from that same spot but this time it's due to the bearing play. My mechanic says the diff has to be replaced.
There didn't seem to be a lot of play so I'm hoping to hold out for awhile until I can source a good used diff. Would it be unwise at all to drive with that bearing play for the next little while as long as the gear oil is kept topped up?
Old 01-11-2023 | 10:05 AM
Husknrs2002's Avatar
Default X250 Recall.
Originally Posted by chuckh007
give me your E-mail address.
Hey I have a 09 Jaguar XF SC with a x250 rear end that has completely failed. My Vin falls within the listed vin numbers but Jaguar say it's not covered.
  #30
Old 01-12-2023 | 01:41 AM
litteredwithfaults's Avatar
The recall was meant for the factory defect where their supplier used bad/wrong sealant that broke down the gear oil and eventually the diff. This would manifest early within the original warranty period.
sogood
09-15-2015 08:35 AM
OkieTim
09-08-2015 05:48 PM
Xkr x100
09-06-2015 09:50 AM
OkieTim
09-02-2015 01:48 PM
Quick Reply: Rear axle leak please help!
