Rear Differential Oil Filler Plug?
Hi Guys,
Looking for some advice. I have 2011 XFR and would like to change the rear diff oil. Had a look in the workshop manual and under the car. It appears the filler plug is nicely hidden with little access to get a key in there. I'm guessing it's a hex key but not sure the size/best method for removing the plug. Refilling will likely be 1.1 litres via a hand pump..
Thanks in advance...
In case anyone else is looking found these:
Bondhus 20599 0.050 - 3/8-Inch and 1.5 - 10mm Stubby Ball End Hex Key Double Pack - Hex Key Short - Amazon.com
I think your solution is much stronger though. Not sure how tight that bolt is in there.
![Bondhus 20599 0.050 - 3/8-Inch and 1.5 - 10mm Stubby Ball End Hex Key Double Pack - Hex Key Short - Amazon.com](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
The XFR diff case is different than the 09 Supercharged correct? The XFR and later Supercharged models have the E-diff so I imagine it is. I had no issues accessing the fill plug on my 09. No tools were harmed. ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Here is the fluid I used:
Amazon.com: Royal Purple 01301 Max Gear 75W-140 High Performance Synthetic Automotive Gear Oil - 1 qt.: Automotive
I sucked out all the old fluid with a cheap hand pump and pumped in the new fluid.
Here is a shot of the 09 Supercharged diff case:
![Amazon.com: Royal Purple 01301 Max Gear 75W-140 High Performance Synthetic Automotive Gear Oil - 1 qt.: Automotive](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
