Rear indicator light working like a christmass tree light
Hi guys. I’m new on the forum and i have a problem with my rear right signaling lamp. When i try to use it, it doesn’t work properly, it just have small flashes. Same ideea when i turn on the hazard lights and on the dash, the signal is very short, not like the left one. Did anyone else experienced this problem?
Greetings from Finland! Rear signal dying is quite common. Mine have both been replaced and car is 2012. It`s easy to test if the problem is in the lamp cluster. Just unmount both rear clusters and connect them to the opposite side. They don`t fit to the body, but will fit to the electronics so you can test them. Then just order new cluster, mount it and voilá! Money saved! It`s very easy to diy.
rlwpromo
07-16-2024 03:11 AM
timfountain
07-17-2010 10:25 AM
