Rear wheel bearing failure - repeated
Hello:
I have a 2012 XF base - 5.0. I am on the third drivers rear wheel bearing in the last 3 years. The car only has about 65,000 miles so I don't drive it much but keep getting repeated bearing failures.
The first sign was when I had new tires installed and found the entire wheel rather loose. I replaced the bearing myself and all seemed good until about 18 months later. I checked the wheel and found it loose again. This time I replaced the bearing and purchased a new knuckle. there was minor evidence that the initial bearing failure had spun. I heated the knuckle/froze the bearing and it fell right in. I had the hub pressed in by a local machine shop. I torqued the shaft nut to the suggested 300 Nm (200 ft-lbs). All was good until I recently found a little play in the wheel again. Is there a trick to these things? I'm a mechanical engineer and have worked with/designed rotating equipment for most of my career. With only four real parts there (3 if you disregard the snap ring) I can't see anything causing this. I'm tempted to put a new bearing in with a new hub this time (all parts replaced) to see if that does anything. But the hub doesn't appear to have any damage (although it does take quite a lot of pressure to get it into the bearing).
Any thoughts for people smarter than I am?
Hello:
Use a good quality bearing
