Relay?
Well if it's like the Gas engines, their is no serviceable fan relay, only an electronic fan controller that is sold as one with the fan. From the petrol service manual,
"An electric, variable speed cooling fan is installed in a shroud attached to the rear of the radiator. The cooling fan is operated
by a fan control module, integrated into the electric motor, under the control of the ECM. An electrical connector at the RH side
of the shroud provides the interface between the cooling fan harness and the vehicle wiring."
Saemetric
12-05-2014 05:56 PM
