Remote keyless entry after the fact
Does anyone know if it is possible to install the Smart Key keyless entry option on an existing XF (2010 Luxury)? My XF is in the shop for minor work, and I have a 2011 XF Portfolio as a loaner. It has the keyless entry and I have to say I would love to have that. I bought my XF used from the dealer, so I didn't have the option. Would the wiring harness be already in the door, and the handle just need to be swapped out (and a program change, I'm sure)?
What about after the fact optional upgrades in general?
Thanks!
Thanks!
My guess is that it would not be feasible. Besides any door handle changes, I think there would be one or more transmitter/sensor modules and maybe a control module that must be installed to make the system operational. I doubt that there are any major OEM electronic features that can be added to an an existing vehicle.
mitch.thompson (04-24-2012)
Not to mention the key fobs x 2. There will be a proximity sensor to add somewhere, maybe more than one. the ECU is probably the same in all cars just software will be different. It is the electronic hardware and installation that will cost money. Jaguar may not allow their dealers to add this stuff. Option pricing is normally very profitable. This is one reason I try not to buy any options. If dealers could just add selected options for competitive prices the profitable option packages would be a tough sell. It's a bit like cable or satellite TV packages. Some channels only sell because they are packaged with popular channels!
So, I was looking at the manual tonight and it seems like there is a transmitter in the key for our smartkey and a module to recognize it (blinking red light). Now....I'm just supposing that on some cars, Jaguar may have just not installed the fuse to allow the keyless entry to work.
Unless someone can definitively tell me that the door handles are different with this system installed - I'll check fuses tomorrow. As an aside, Land Rover used to manufacture some of its vehicles with "additional" features that were just disabled via fuse or switch omissions. Fingers crossed....
Cheers,
On a similar note: Have anybody seen a price list for adding iPod and USB interface? Even if the wiring has to be changed it is only from under the driver's seat to the bottom of the cubby in the centre arm rest. I believe the module under the seat (Portable Audio Module) is the same but even if not it would be a doddle to replace. Then some programming to the Integrated Audio Module (the main unit) to make it work.
Per - I did check with a person on ebay that sells OEM parts on if the module can be added and they said that they are not aware of the ability to order that specific part. I would think it should be a simple add-on as the main unit should have the ability to add the various interfaces, but as we are seeing with the keyless entry and Jag's lack of willingness to offer any OEM parts unless they are break/fix it might be hard to track down the part.
zdrapec
09-25-2015 05:49 AM
