Removal of Door Sill Tread Plate
Anyone have advice on how to remove specifically the driver door sill tread plate? I’ve still got some remnant of the plastic delivery interior covering under mine that no matter how hard I try to stuff back under it, pops out over time. I tried to see if there were any posts on putting in the Illuminated sill tread plate as that would cover this removal, but didn’t see any. It kind of feels like it will just pop off and without any visible attachment points, that must be the case. But before I break it, I thought I would reach out to see if anyone knew of the appropriate way to remove it.
TIA
TIA
Stop spamming the board! You don't need to bump every tread plate thread. They all go to the top and we can all see them. lol
Find a wire that is hot when the lights are on and run that down to the tread plates. It won't be easy. You'd have to pull some panels and do some testing with a multimeter.
99xk8guy
06-05-2023 06:28 AM
2009, 2012, aluminum, door, illuminated, install, instructions, jaguar, plate, plates, replacement, sill, sills, tread, treadplates, xf
