Removing Cats
I know this isn't exactly what you are asking, but there is some good information in this thread.
https://www.jaguarforums.com/forum/x...st-done-90460/
Gpalace (10-22-2014)
Thanks Thor82....some great information...I think it wil come done to personal preference on the sound issue...I love the crackle and popping of the Ftype 550's...not saying what I am about to do will duplicate.
Wondering if any o2 sensortype issues/ check engine light etc.?
Again thanks....
Blackcoog?
Again thanks....
Blackcoog?
You'd likely have O2 sensors popping check engine lights. I'm not sure what will work on the XF as far as fooling the O2 sensors. I was able to use O2 sensor spacers on my 2006 Audi S4. On other cars I've had to wire in a RLC circuit into the O2 sensor wiring to delay the signal as if a cat was still there.
Search the other forums. Some S-type R or XJ members may have done this.
A nice set of high flowing downpipes without cats should see a good bump in power on any FI (turbo/supercharged) car. The less restrictive the better. There are a few XJR threads with various dynos. In general I'd think you'd see 15-30whp.
Gpalace (10-23-2014)
My two-cents, you don't need to remove the cats. I can see you've got the Mina exhaust (which I also have), you just need to have the centre resonators removed, replaced with straight pipe and an X-pipe. Total cost to have this done at a local shop: $120. The burble and pop (and growl) are AWESOME. No drone at cruise.
This was after the Resonator delete (but BEFORE the Mina)
This is from the inside of the car, AFTER the Mina exhaust. (I also closed off the resonators on the intake to hear more of the supercharger) but unfortunately I was in too high of a gear to really hear it... the S/C sounds a LOT louder at lower gears).
The following 2 users liked this post by aliensporez:
Gpalace (10-27-2014),
thecurryman (02-10-2015)
Can't wait for pics of both mods. Can you have them take some undercarriage shots? I want to see were they put the O2 foulers and how far down stream.
