Replacing air filter question
I looked at the filter box today and there are several torx screws. Do all of them have to be unscrewed and there was also an electric plug that seem to be in the way. Do I need to take any spring special precautions with it.
I'm looking for any helpful tips to make this go easy. Thanks
Received 3,226 Likes
Assuming you have a V8 either NA or SC then it's fairly easy. Undo all the Torx screws (T20 from memory) but don't take any of them right out, they are "held captive" by the filter box tops anyway. I accidentally took one all the way out then of course I dropped it in the engine bay never to be seen again!
Then the top lifts off just far enough so you can ease the old filter out and put a new one back in.
No need to remove any plugs, I guess you are looking at the MAF sensor plugs.
chekraze (08-25-2016)
See here: https://www.jaguarlandroverrenoparts...ir-intake-scat
Part #4 in the diagram, part number C2Z9051, $0.96 each.
Received 2,192 Likes
