replacing the battery in my 2012 XF
as another poster wrote in the preceding post, this is a common problem, after changing the battery.. try all the windows a few times - up and down.. same with parking brake.
Yeah, I've done it many, many times. Both front windows are working, as is the brake. Not sure why the rears aren't, but it sounds like there's no particular trick to it. I'll just keep trying.
today, at a local store, I saw a "memory saver"
On one end, it goes into a diagnostic port.
On the other end, it goes into a cigarette lighter (presumably, a jump start battery)
I had my battery swapped at that store. $117, including installation and taxes.
And they preserved the memory settings just fine.
Great deal!
Great deal!
XJL (11-19-2015)
Take a look at this for a cheap memory saver.
Amazon.com: CTA Tools 3002 Computer Memory Saver: Home Improvement
Instead, you might wish to consider but frankly, I would not use any of these.. they might blow a fuse!
Just a side note of caution for people contemplating using an AGM Battery...
AGM = (Absorbent Glass Mat), which means the cells (6/2V) of the battery are factory filled with a minimum amount of free electrolyte (H2SO4), usually less than 50 mL ..the AGM manufactures all recommend a lower than normal charge rate vs what the car puts out normally for a flooded wet cell lead/acid battery...so be careful..you may gas out all the electrolyte's water content sooner than that of a normal flooded cell battery...Thereby killing the battery sooner.
#28
I recommend this one... You can steal the power from another battery or another car.
Automotive Car Computer Black Box Data Memory Recorder Engine Maintenance Tool | eBay
#30
Interstate are rated as one of the top 3 batteries. But they are expensive.. Perhaps $200+. I got mine done at a local farm and fleet - store brand made by East Penn. They were able to save the memory. And it cost only $110 (made by East penn) I prefer to replace battery, every 3 years. Being in wisconsin, it is not worthwhile for me to even wonder.. I realize that they can do load test etc.. But for $110, its cheap for peace of mind.. Btw, I believe east penn is a large manufacturer for Duracell auto batteries.
#31
Good to know..My Jag tech friend recommended Interstate also...did you by chance get a style name or model number for the Interstate battery?
#33
thanks.
#34
I replaced mine with the Interstate AGM battery and it works great. I can run my stereo (with a non-digital 900w amp) for a while and have no issues starting it after. I also don't drive it for periods of up to 2 weeks other than very short errands and it always starts up strong.
I know I paid more than I could have, but after having a Diehard Gold AGM in another vehicle for 5 years and running it down fully twice, it still starts up very eagerly every day, even if it's sat a week or so.
#36
I wonder if AGM batteries are better for starting at -10 F, overnight? Maybe they are? Maybe they won't freeze as much as the regular kind?
If so, they would be so worth the extra money..
I am told that AGM batteries are superior.. not sure in exactly what features.. Hopefully, higher cca?
#37
I just talked to my Jag-Tech friend and he said they told him at the Jaguar training school that it isn't needed to re-calibrate the battery monitor as it relearns over a short period of time and settles in on it's own..All it does is monitor the charge rate of the battery and as the battery gets closer to the end of it's service life, it will start asking for more charge current to get it back to normal...the New battery will tell the monitor it don't need as much and the system self calibrates for the new battery after few minutes of charging..
tgibbs94 (01-27-2016)
#38
#39
I have already written that I replaced the battery. The calibration part I was asking was actually about re-learning the window auto up function (as someone else wrote). I went to a local store.. they used a battery saver and swapped my battery. All works well. I think they used a battery saver which connects to the diagnostic port. They were selling one there. I would not have used it.. but they probably used it.. and it worked out fine.
Glad your battery change worked out good.
Now go have a Brat and Beer for me this weekend..
#40
DPK (01-27-2016)
