Resetting service light/message - RESOLVED
Old 02-02-2019 | 05:19 PM
mrNewt's Avatar
Unhappy Resetting service light/message - RESOLVED
So, I followed the steps to reset the service required message/light but so far I am at a loss...
I have followed the video below and I am able to get the "Resetting Service Mode" message, but no amount of waiting resets anything. I waited like 3 minutes and still no reset completed message.
What I am doing wrong or what could stop it from actually completing to reset the service message?
Last edited by GGG; 02-05-2019 at 02:33 AM. Reason: Add "RESOLVED" to thread title
Old 02-02-2019 | 05:34 PM
OzXFR's Avatar
Did you keep the fog light and trip buttons pressed until the message went away, and then let go of them?
Old 02-02-2019 | 05:37 PM
mrNewt's Avatar
I did, holding both for 3 minutes until my fingers started to hurt a little. Message never want away.
Old 02-02-2019 | 05:56 PM
Jag#4's Avatar
This is more art than science. It took me multiple tries before I appeased the gods and got it to work.
They truly prefer you to use the dealer.
Old 02-02-2019 | 06:00 PM
mrNewt's Avatar
I know is tricky to get the " Resetting Service Mode " - but once you get it I assumed you just wait until it resets... 10, 30 seconds. But no... it just doesn't do it...
I did got the message... what else I'm missing... should I perform a rain dance before trying again?
Anyway, I guess I need to invested in one of those diagnostic tools sooner that I wanted ... I think those allow you to reset the service light that way.
Old 02-02-2019 | 10:27 PM
davetibbs's Avatar
So this is from the XK Service Manual but the software seems to be largely the same as the XF, so these steps might be worth following:
Note each step needs to be carried out within 3 seconds. Maybe make sure to press and hold the trip computer cycle switch before pressing and holding the rear fog lamp switch?
Falkens_XF (05-28-2020)
Old 02-02-2019 | 11:00 PM
mrNewt's Avatar
OK, I will try this one more time...
The pressing bits is done properly - I DO GET " Resetting Service Mode " message.
Problem is, that the message just stays on without returning a " Service Mode Reset " even after 3 minutes.
I will try again tomorrow... but not sure what in the world is going on.
Old 02-02-2019 | 11:03 PM
Bigg Will's Avatar
Timing is the critical element here...lol, just have to keep at it.
Old 02-03-2019 | 01:33 AM
mrNewt's Avatar
So basically even if I get that message on the dash is still not guaranteed!?
Man can they make it more complicated than this?...
Old 02-04-2019 | 07:35 PM
mrNewt's Avatar
I've figure out what the issue was... embarrassing a little lol.
My timing was correct, the only problem was that I had a Bluetooth OBDII scan tool connected to the car and for whatever reasons that was interfering with the reset function.
Once I got it disconnected, it got reset withing 10 seconds as they say it should .
The more you know...
The following 3 users liked this post by mrNewt:
davetibbs (02-05-2019), gctippett (08-15-2022), GGG (02-05-2019)
Old 02-05-2019 | 12:01 AM
davetibbs's Avatar
Nice spot! I wouldn't be embarassed by that, it's not an obvious reason for the reset not to work.
Old 02-05-2019 | 02:39 AM
Originally Posted by mrNewt
..... the only problem was that I had a Bluetooth OBDII scan tool connected to the car and for whatever reasons that was interfering with the reset function. .....
Thanks for posting the resolution. I've added "RESOLVED" to your thread title.
A lot of members leave a scan tool or Torque Pro connected but I doubt many would make the connection this was interfering with the Service Reset procedure. I'll file that one away in the memory bank for future reference. The question is bound to turn up in other model forums.
Old 02-05-2019 | 05:12 PM
mrNewt's Avatar
Thanks guys - hope it will help someone out there!
Old 06-09-2021 | 03:04 PM
Cwmills55's Avatar
Default Same problem here. I don’t have anything connect and it still won’t reset
I have the same problem, however I have nothing connect and it still won’t complete. Any other suggestions?
Old 03-27-2022 | 12:01 PM
JayXF's Avatar
Did you figure this out my car is doing the same it will pop up resetting but won't actully reset no matter how long i hold it and i have nothing connected
Old 06-13-2022 | 05:49 PM
kkurulak's Avatar
Thanks davetibbs for the XK service manual instructions.
I just services the two jags and found it to be the closest success rate for reset I have had in a long time. I played a bit with it and found that even though they state "Immediately" , it is not super important to rush. I now can easily process the reset function by following the outline as described but without haste.
1. While holding the fog light button, press the start button (No foot on brake)
2. When the shifter knob starts to rise and the Jaguar logo pops on the center screen, let go the fog light button (Assuming you already released the start button)
3. Press and hold the trip button, then press and hold the fog light button (In the instrument cluster the service indicator will display it resetting and after 30-60 seconds it will post a complete indicator.
4. Release both buttons and turn off car.
I did have issues if I left the door open, had connections to the OBDII, Bluetooth on the media USB or even if I had a phone trying to connect when car is turned on.
Kevin
Old 06-15-2022 | 01:13 PM
pab's Avatar
pab
>When the shifter knob starts to rise ...
But w/o the foot on the brake the engine won't star, and the shifter won't rise, will it?
Current Hers: '13 Lexus ES350
Current Mine: '15 Jaguar XF (X250) Portfolio AWD
Jaguar - making mechanics out of customers since 1935
Old 06-15-2022 | 09:09 PM
kkurulak's Avatar
Good catch, sorry about that, I must have had my wires crossed. I was intending to reference the auto vents and had the shifter on my mind. Here is the corrected post and I do apologize for the error.
2. When the auto vents starts to rise and the Jaguar logo pops on the center screen, let go the fog light button (Assuming you already released the start button)
Kevin
Last edited by kkurulak; 06-15-2022 at 09:11 PM. Reason: could not edit previous post
Old 06-29-2022 | 01:05 PM
pab's Avatar
pab
Hey, does the warning light ever go off?
My light came on stating that there were X miles until I needed service. I haven't been driving the car much and I noticed that the mileage warning was decreasing much faster than I was driving. It had dropped to a 1500 miles to a couple of hundred, where I'd only drive a few hundred miles.
Yesterday, when I drove the car is sitting for most of a week, the service warning light didn't come on.
Does anyone know if the service warning light self-cancels?
Old 06-29-2022 | 01:06 PM
pab's Avatar
pab
dropped "from" 1500 miles to a couple of hundred ...
Quick Reply: Resetting service light/message - RESOLVED
