Restricted Performance - 2011xf premium
can fuel additives to decarbonize cause restricted performance alerts?
just drove my XF home from servicing after a misfire. They replaced a coil and spark plug. Was running fine fine this afternoon, but the restricted performance message appeared again this evening, but went away after a couple of minutes.
thanks!
thanks!
thanks!
thanks!
You need to codes to know what is going on. Guessing on fuel additives isn't going to get you anywhere.
Thanks guys. Continued to get the Restricted performance note on the weekend, and the check engine light came back on as well so I took it back to the dealership. They'll check the codes. After replacing a coil and spark plug, we thought we'd solved it, but clearly there's something else going on.
