Restricted Performance - 8th Visit - Help!! RESOLVED
#41
Hey Hey ,I have some questions about jaguar xd 3.0d 2011. because i have problem with popup RP. the error I am showing is the air flow meter, so I dismantled everything and cleaned it thoroughly. after restarting, the error was gone, and so every time I turn off the engine and wait for some time, the error disappears, but returns after some time after driving a few or a dozen kilometers.unfortunately mechanics. my neighborhood can't help me.I read on the jaguar forum full of good opinions that you are helpful, maybe you already had a similar case and suggest what I could check.Greetings from Poland.
Evoo (01-15-2023)
#42
Deano - great work - looks like a clever solution - I like the idea of first drilling the ends of the cracks to avoid it propagating further - very clever.I have some photos of my cracked manifold below - was amazed how thin the crack was. I had to look for quite a while to find it - a long thin crack along the corner - hope you can see it in the photos - if not email me and I will send you full res.I am sure your fix will work. I have kept the old part just in case. If it goes again may need it.Did you remove yours Deano to fix it, or do the fix in situ?
#43
The same problem
Hey I checked everything today, and I have the same problem as you. at least now i know where i stand. I only have concerns because I need to drive 1800km home at the weekend and I don't know if something can happen or just limits the power. I'm going to put some glue on it to make it a little better. I've seen spare parts for €120, will they be ok?
#44
Evoo (01-15-2023)
#45
#46
I think fitting cost was quite expensive when I looked and I didn't want to fit something that could be a short time from failing again. If you glue it, then it could be worth adding straps 90 degrees to the crack to add some more strength, even a cut up leather belt or strap could help. Good luck.
Evoo (01-15-2023)
#47
03s-type_sport
11-24-2017 05:09 AM
rlwpromo
02-24-2013 08:08 PM
