Retrofit XFR Rear Diffuser
Old 12-04-2013, 03:09 PM
ddanielcigars's Avatar
Looks great!!!
I see that you have the Sport Pkg type rear valance too.
Did you swap just the original black insert for the XFR type w/ fins?
Also, did you replace yourself? If so how easy/difficult?
Thanks in advance!
Old 12-04-2013, 04:28 PM
glenonoka's Avatar
Yes, I just swapped the xfr panel with the old one. It was fairy easy to do, maybe 20 minutes tops.
I had to pull down on bottom edge of the old panel a bit to get the screw push pins to unscrew. Then I started popping the tabs on the sides first. Reaching behind and pushing them down so they slipped out of the holes. After the side tabs were free, you just kind of yank straight back on the upper tabs and it comes right off. No scratches.
You will see how the tabs work clearly with the replacement panel in hand. That was what I used for guidance. There were no instructions included.
The diffuser is painted. Much nicer than the flat black color of the old panel. The feel in the rear is much more solid with the diffuser. I was amazed at the difference those little fins add to the rear stability when driving.
I can take a picture of the back of the old panel if you would like to see the tabs before buying.
Old 12-05-2013, 12:01 AM
Thanks for the thorough description.
Yes, a photo would be a big help in my decision to do it myself or have the dealer do it.
The local dealer has the XFR insert part for $225.
Is that a decent price?
Old 12-05-2013, 05:05 AM
glenonoka's Avatar
That is a decent price. I paid 196.
Jaguar C2Z16212 Valance Valance Panel | eBay
Looks like he is selling another at this price.
I'll get you a picture later today.
ddanielcigars (12-26-2013)
Old 12-05-2013, 06:09 AM
Terrific. Thanks again for all the information and the link.
I definitely know what I want for Christmas.
Old 12-05-2013, 12:34 PM
glenonoka's Avatar
The holes at the top are the forward most part of the panel. They are where the screw push pins go through.
A picture of the three different tabs.
A close up of the lowest side tab. It is very flexible. you just need to reach around and push it for the tab to slip out.
The upper side tabs and the top tab. All of the side tabs should be disengaged from the bumper before attempting to remove the upper tabs from the bumper.
Attached Thumbnails Retrofit XFR Rear Diffuser-1425688_10201123674356512_864751365_n.jpg   Retrofit XFR Rear Diffuser-1463639_10201123674556517_2095137193_n.jpg   Retrofit XFR Rear Diffuser-971609_10201123674276510_1016549439_n.jpg   Retrofit XFR Rear Diffuser-1472769_10201123674716521_945293921_n.jpg
Old 12-05-2013, 09:51 PM
Such a huge help. Thank you. Pictures are truly worth a thousand words.
I think I'll try this myself. I placed my diffuser order today and will post before and after pics.
  #28
Old 12-09-2013, 08:53 AM
Reaxions's Avatar
Originally Posted by chXFS
What are everybody's thoughts on this project? I have seen many people over in the UK are doing this. I know there is some work involved but nothing crazy, all you have to do is make new slots for the tabs of the new valance. A dremil tool would do the trick. There is a guy on you tube who does a video on it. I know Mina offers the the Diffuser and I sure it's top notch. I called there and they said it comes in one piece and I was a little worried about how that looked considering I would want it two toned. The factory set comes in two pieces and the finned underplate already comes in gloss black, the top valance is all that needs to be painted. Finned underplate - C2Z16212 ($182.40) Top surround - C2Z16211 ($60.38) so that's a huge savings and to have OEM parts. Has anyone done this?
Yeah, I did it (about a year ago or so, I think). I posted pix on here somewhere. I actually had a body shop do the work, and had to sort of guinea pig the design with Mina, but I'm very happy with the final result.
Old 12-09-2013, 10:17 AM
caviarjag's Avatar
I also used a mina diffuser. They painted it for me and then I installed it. The install was relatively straightforward. I had to trim one tab slightly, but other than that it went very smoothly. The hardest part was removing the old diffuser.
  #30
Old 12-10-2013, 09:31 PM
jlocc619's Avatar
Originally Posted by Gn4hir
jlocc619
I'm curious, on a scale of 1-10 with 1 being easy breezy and 10 being oh Sh*t that was a pain.. how would you rate the install of the Mina diffuser and exhaust?
I ask, because I suckered my buddy into helping me do this same project a couple of weeks ago and it took the 2 of us about an hour and some degree of cursing.. I would rate it a 6.5-7.0 on the scale because 1. it does take two people and 2. It didn't seem it was going to go on until we muscled it into place. I felt sure I was going to break a tab or have it pop off when I hit the first bump.
Wish I'd known you were doing this we could have had a diffuser party.
JW
I'm going to rate it a 1 since I had Jaguar put it on for me. I tried at first by myself and I was worried I would crack the carbon fiber. The exhaust is just a bolt on, so not much to it there except for the need to maneuver the bolts/hangars so the tips don't vibrate.
On another note I see you did your tune and exhaust with Eurocharged. I was down there last October and I was the first Jaguar they had seen. It was him and his partner who lived in Boston (who had a 1,000 hp Porsche on the dyno). Anyhow, I had some issues after my first dyno run(smoke, which Jag later identified the root cause) and never finished...or ended up going back. Long story short, are you pleased with it and what did you pay? I was going to pay $975 out the door last October for pulley, tune, and before/after dyno. I see they were offering a group buy for $800 not too long ago. What did you pay?
  #31
Old 12-26-2013, 01:50 PM
glenonoka,thanks again for all your help! Once I had the old diffuser off, I had to take special care in making sure none of the tabs missed their slot by folding instead of "snappping" in place. Other that that, it was a breeze.
Attached Thumbnails Retrofit XFR Rear Diffuser-jag-1.jpg   Retrofit XFR Rear Diffuser-jag-2.jpg
  #32
Old 12-26-2013, 01:55 PM
Executive's Avatar
Looks fantastic. Always liked the rear valance on the XFR/SC models better.
I have been holding back, but you guys are going to make me spend money.
Daniel, did you paint it yourself? Did you order it painted? What comes painted etc? If you can give some details, that would be great.
  #33
Old 12-26-2013, 03:32 PM
Here is the eBay store I puchased from:
http://stores.ebay.com/RUSNAK-Pasade...p2047675.l2563
the part numbr is: C2Z16212
The outside (area that shows) came painted gloss black (matches my front grill since I have the Sport Pkg.) the back or inside is standard black plastic, but is ready to install.
Once out of the package, be sure not to lay it on a rough surface, as it will easily scratch. Contact them and I'm sure they'll take good care of you. Great communication and customer service. Good luck.
  #34
Old 12-26-2013, 07:56 PM
glenonoka's Avatar
Looks great!
ddanielcigars (12-29-2013)
  #35
Old 12-27-2013, 09:43 AM
WRXtranceformed's Avatar
I'm assuming if your car is pre-2012 you need more than just that part? I'm pretty sure my rear bumper does not have an insert section.
  #36
Old 12-27-2013, 11:21 AM
chXFS's Avatar
It does, but the tabs won't match up. You would buy both pieces and dremel new slots. I started this thread explaining all this and a member was kind enough to put up a video on how too. Another option we have is Mina, the tabs match up so no cutting into to the bumper. Go to the start of the thread.
WRXtranceformed (12-27-2013)
  #37
Old 12-27-2013, 05:20 PM
caviarjag's Avatar
I went with the Mina on my 2011 and it was a very simple install. They shipped it to my door completely painted to make things even easier. I would not hesitate to recommend them to anyone.
  #38
Old 12-27-2013, 10:04 PM
Nice thanks dude!
Good to know, I was leaning toward the CF mina version. I didn't see the option for MG to paint it for you on their site, should I just give them a call? Thanks for the help!
  #39
Old 12-28-2013, 12:08 AM
caviarjag's Avatar
Nice thanks dude!
Just give them a call. It seems they offer a lot of services and parts that do not make it to the website. I too was considering the CF version but thought it might not be the best fit aesthetically for this car and me.
  #40
Old 12-29-2013, 10:07 PM
My XF is a 2012 w/ Sport Pkg, meaning the rear bumper and valance are in two separate pieces like the XFR. I only replaced the original flat black insert with an OEM Jaguar finned XFR diffuser just as glenonoka did in the earlier posts.
Quick Reply: Retrofit XFR Rear Diffuser
