RPI Air Intake Scoops ( Calling for CA, XF Supercharged Owners )
No worries. This car is just a weekend car for me, so it's as much a hobby as real transportation. Love being able to open up options for myself and others to modify their cars and get the optimal power from this great motor.
The thing I like about the ram air concept is that it helps the heat soak issues I know our cars suffer from. More cool air means more power and efficiency across the board. So I feel like this will make significant freebie hp and will only enhance the investment in the tune and pulley I already made.
Looking forward to the process of getting these made.
My car went to the dealer to have code P2601 fixed today. I had to run it pretty hard to get it to give me the "Restricted Performance" light and throw the code so it could get fixed. From what I understand it's a faulty supercharger coolant pump that only really matters when it's working hard.
When I get it back I'll arrange a time to go to RPI so they can have a look. Hoping to do so on Friday if all works out. Will keep you guys informed.
This mod will fit any XF there is. Even the 6 and 4 cylinders. Facelift-preface lift doesn't matter. All XFs share the same pluming from the bumper to the air box. You either have one or two. But they are all the same.
Metal plumbing is not always the best thing under the hood of a charged air engine, it conducts underhood heat and warms the air quite a bit.
#32
I've solved the problem on previous turboed cars by wrapping any charge piping in header wrap. Unbelievable how well it works.
#33
TCP performance intake- Blackcoog can assist .. I just had it installed ...couldn't be happier.....I may wrap mine .
#34
#35
Oh I have a 09 XF SC in Texas if that matters....
#36
The following 2 users liked this post by 2010 Kyanite XFR:
aliensporez (12-08-2014),
Gpalace (12-08-2014)
#37
So I went by RPI today and it doesn't look like it will work. There is a shelf in the area along with the tubular bracing and there really isn't much room for more air. Eloy said maybe 5 hp. So I decided it wasn't worth the effort it would take to get the fabrication and testing done.
Sorry guys but now we know...
The following 5 users liked this post by 2010 Kyanite XFR:
aliensporez (12-11-2014),
chXFS (12-10-2014),
fabfive (12-11-2014),
Gpalace (12-10-2014),
sasovrd (12-11-2014)
#38
#39
Has anyone considered re-routing the cold air supply to the air boxes from behind the grille to the lower side grills below the headlights? Obviously the risk of hydrolocking while driving through deep water is increased, but the benefits of a more straight path can't be ignored.
#40
