Screenwash not working
Hello All.
Some help please on my 2010 XF 3.0 D.
My screenwash pump is not working.
I have replaced the pump but nothing, so checked to see if the pump was receiving power and it was not when engaging the switch on the stalk.
I have checked the fuse and that is ok.
Would the next step by to change the relay? What number relay would that be as i can't find reference to a diagram online.
Could it be the stalk switch that's failing? The wipers are ok.
Any help is appreciated.
James
James
Hello All.
James
James
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1741x574/pump_washer_df13b0f68c6bb6ab83fcd93bf6969ec65993ad33.jpg)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1195x242/washerpump_b5b93d231b65dfb5a63355d790290de7cabc09d1.jpg)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/943x764/ipc_stalk_a60596a7cf7f13cfae87dc492f676ec8b2486a56.jpg)
GGG (06-28-2023)
Mine recently failed; the headlamp washer works but the screen does not. The wiper cycle does work. I had the same issue with my 2011 XK—it has two pumps, one for the screen and one for the lamps. I replaced the screen pump and that fixed the problem. I’m going to try the same on my XFR. Aftermarket pumps are inexpensive and will fit.
AlexJag
10-13-2021 02:41 PM
