secondary air fault
Old 06-17-2018, 10:44 AM
jakesdad's Avatar
Default secondary air fault
Happy Father's Day guys.....hey, on this 2009 XF which some of you know has been behaving strangely for a bit.....newest issue that just popped up is 0411 which shows as secondary air pump insufficient? .....I checked the fuse it is ok. I did not pull the relay for fear of creating some unforeseen nightmare as occurred recently when I changed the car battery...so......I decided to clear the code and cross fingers. The moment the code cleared, the air pump kicked on and was noticeably audible, sounding kind of like a radiator fan, but contrary to posts I have seen that this fan is only supposed to kick on momentarily at start up, it remains on even after driving the car around the block. What's up? Is it supposed to run continuously? Is it harmful for it to run? I'm kind of guessing the relay might be bad and sending continuous run signal?
Old 06-17-2018, 12:20 PM
wardo5757's Avatar
I had that code before, turned out to be a broken vacuum hose.
The hose attaches to the relay looking thing in the picture (relay on the right, blower on the left) and runs to the blower. You will have to remove the drivers headlight to get to it, but it was easy to change.
Hope this is the same issue for you, its a very easy fix if so.
Old 06-17-2018, 12:55 PM
jakesdad's Avatar
thanks, Wardo
Old 06-21-2018, 01:24 PM
nasa25's Avatar
I second broken vacuum hose
Old 11-11-2022, 12:24 AM
jose3030's Avatar
Greetings,
Sorry for reupping such an old thread but it's pertinent to my question today.
I have a P0411 code that just appeared.
There appear to be '2' Secondary Air Injection Pump Hoses.
Between C2Z4526 and C2Z4527, which one is it?
(I've yet to take anything apart or start troubleshooting, I look to do so over the weekend. Would love to have all parts readily available when doing the work or at least know where to start looking first)
PART #: C2Z4526
and
PART #: C2Z4527
Old 11-11-2022, 12:28 AM
jose3030's Avatar
Old 11-11-2022, 12:35 AM
jose3030's Avatar
BTW, I did check the fuse and it appears to be OK for now.
Just initial quick look.
Old 11-11-2022, 10:30 AM
karamayoko's Avatar
So youre gonna buy parts before verifying if its the parts you need? seems a bit odd to do it that way especially the prices being what they are, but hey your money your problem. Just my .02 cents thought. best of luck mate!
Old 11-11-2022, 10:32 AM
jose3030's Avatar
Just wanted to know which of the two is the one the original poster was speaking about.............................
Old 11-11-2022, 10:45 AM
karamayoko's Avatar
yeah, I get where you're coming from but its always best to verify/check before buying parts that way you arent sending parts back and waiting for $$$ to hit that checking account. Just because they had this problem doesn't mean it'll be the same part you're having problems with. plus you also stated " Would love to have all parts readily available when doing the work"
Old 03-17-2024, 05:19 PM
JaguarTom's Avatar
Where is the Secondary Air Injector Relay located on a 2009 XF?
Rocky15
08-26-2020 03:56 AM
JayJagJay
04-18-2020 01:17 AM
Brewtech
XJ40 ( XJ81 )
02-25-2020 10:55 AM
Rodney Dell
09-20-2016 11:54 AM
alfatim
04-15-2016 11:11 AM
Quick Reply: secondary air fault
