"Service Required" message - questions
My car recently started displaying "Service Required". it will appear for 3 seconds on start up and disappear. My XJ used to do this all the time at start up, it meant nothing.
my car also just hit 40k, had oil changed at 38k.....so is it a mileage based alert? or something more that needs investigation?
Its based on Time and/or mileage. Whoever changed your oil probably forgot to reset it. After a while it will stay on longer. If it was a dealer I would take it back to reset it if convenient. if not here's the procedure - May take a few tries to get it reset.
Resetting service reminder:
1. Press and hold rear fog lamp switch
2. Turn ignition on, do not start engine
3. Release rear fog lamp switch
4. Press and hold trip button (end of left side stalk)
5. Press and hold rear fog lamp switch
6. See "Resetting Service Light" message in message center
7, keep holding till the message says its reset, let go too soon and start again
The following 2 users liked this post by nsl1:
Bpoist (02-13-2023),
carzaddict (06-09-2017)
I did this about 10 days ago and it took me over a dozen tries to finally get it. Reading your instructions vs. what I did, I thought steps 4 and 5 were supposed to be applied simultaneously. Is that not the case? Maybe that's why it took me so many tries. Also, I thought each of the steps had to be done within 1 second of one another. Is this true?
Received 3,210 Likes
Yep - 1-2 sec between steps. As far as 4&5 I think I just pressed the trip button then pressed the fog lamp button and held both for a few seconds until the service reset message came on - You'd think I'd remember exactly as I just did this about a week ago.
May give it another try when I get a chance and report back. I does usually take a few tries to get it right.
Yes, it also applies to the 2009 XF, but it's strange you have never had the message.
Yep, they stopped making the X250 XF in 2015 but they switched over to the X260 XF in the same year and they stopped making it only in June 2024.
Dunno if the same method works on the X260.
