Service warning light 2012 +
I tried the posted procedure for turning off the "Service Required" light for earlier models, but it doesn't work on my 2012. Anyone know the procedure for a 2012. Mine was built 11/11, although I bought it new in November 2012. I believe the car is indicating the 12 month service interval.
Good luck!
Yes using that one. Question though. If the ignition is on and I press and hold the rear fog light switch and then press the start button, it shuts down.
"Trip computer cycle switch" ; the one on the end of the stalk?
1. Press and hold the rear fog lamp switch (while the ignition is off).
2. Press the start button without applying the foot brake.
3. Release the rear fog lamp switch.
4. Press and hold the trip computer cycle switch.
5. Press and hold the rear fog lamp switch.
6. Continue to hold the trip computer and rear fog lamp switches.
7. The message center should display "resetting service mode" and then "service mode reset"
8. Release the trip computer and the fog lamp switches and turn the ignition off.
hlgeorge (12-19-2012)
Well, tried this again. First two attempts, no success. So I said to myself I would try one more time, this time moving as fast as I can. Got the "Resetting Service Mode", but it never indicated "Service Mode Reset". I was holding the buttons for at least 3 minutes. Finally getting cramps in my fingers, I released the buttons. Switched off the ignition and restarted the car......with no Service Required indication!!!! ![Icon Imnotworthy](https://www.jaguarforums.com/forum/images/smilies/icon_imnotworthy.gif)
Where do the engineers get these crazy reset proceedures?
![Icon Verzsilly](https://www.jaguarforums.com/forum/images/smilies/icon_verzsilly.gif)
I can hear 'em now.......... "Hey Joe, <chuckle> let's make 'em do this to reset the service reminder, blah, blah, blah, that'll make 'em pull their hair out, huh???"
If I could only catch one in a deserted parking lot............
Cheers,
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
I tired it for the final time and it did work. Guys i cant thank you enough for having these aweosme fourms.
1. Press and hold the rear fog lamp switch (before the ignition is on).
2. Press the start button without applying the foot brake (do not start the engine)
3. Release the rear fog lamp switch (1sec)
4. Press and hold the trip computer cycle switch (within 1sec).
5. Press and hold the rear fog lamp switch. (within 1sec)
This was driving me insane .. and i am an engineer!
DPK (04-26-2013)
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
I'm good with your 8 points, but I would remove the (1sec) notations. In general, waiting 1 second ANYWHERE in that process will lead to failure. In fact, any hesitations at all will likely cause trouble.
Glad you finally worked through it successfully!
Welcome to the Forum, I think you'll find a great bunch of here. Why don't you make your way over to the New Member Forum and introduce yourself. There are also several "sticky" threads with lots of info about the Forums.
Cheers,
Now that you have gotten rid of the service light, what about the actual service on the vehicle - oil change, etc. ?
Cannot stress that enough. I've seen two wrecked engines recently because oil changes were ignored. And if you have got the service warning long before "standard" service interval it indicates a driving pattern of lots of short journeys, meaning the regenration (DPF) has been attempted often giving diesel in the oil thinning it and if ignored eventually raising level to the point of the engine dieseling out of control on its own lubricant destroying the engine in the process. (Unless the diluted oil hasn't ruined the bearings first.......)
I agree. If the light comes on, it's necessary to bring in for service. But, i don't know what the scenario is with hlgeorge XF. It could have been serviced when he purchased the car a few months ago.....can't comment since i don't know.
Mine is a 2012. Bought it in the summer and only a few months later the service light come on. They said it's due for it's first service, since it was shipped out from UK sometime in 11/11.
Interesting, I got the Monroney Label with the car, but it was kind of dirty and torn. It showed a "ship to" address as Nalley Jaguar. Hennessy ordered me a replacement Monroney Label from Jaguar Corporate, and it showed the "ship to" address as Hennessy Jaguar.
99xk8guy
06-05-2023 06:28 AM
