severley bumpy ride
Ok i Have the jaguar xf 2010 5.0L. My car ride is very bumpy suddenly even on smooth roads. I checked tire pressure and the numbers were all over the place so put them all around 34-35 it was hard me to get 34 exactly but the ride was still bumpy. Also i do have 20's. Can someone give me some insight to what the problem is? Are one of these wheels going to snap off on me while driving. I saw that thread with that issue. Thanks!!
Fall off? Hardly. You've done the first step in troubleshooting already by verifying the tire pressures. If there is no obvious damage to any rim or tire the next step is to take it to the dealer or a reputable indy shop, or even a tire dealer that you trust and have them check the balance and alignment. It is unlikely that the suspension has worn to a point to cause a problem, thus ruling out bushings, dampers, etc. So, unless you remember smacking something really hard, like a curb (kerb for you Brits), then it is probably something minor.
BTW, and I'm sure you know this, tires will take a few miles to smooth out, so to speak, if the car has been sitting and especially if it is cold.
Let us know what you find out.
Thanks for all the responses was at work and school all day and night.
The bumpy ride just happened recently it almost feels as if you have a flat tire and your driving on it but its a bit less dramatic.
The steering wheel doesnt shake but i did hit the same pothole twice that i didnt see the night before the shaking started. After i hit the potholes i drove for a considerable distance and nothing was wrong there was no shaking. Im In ny they are everywhere.
I do have dynamic control but the car wasnt in sport mode.
I know for a fact i need a wheel alignment on the front right tire i just noticed unusally inside wear on the front passenger tire a few days ago but havent had time to get it aligned. Could that be the culprit?Thanks Fellas
ok so my tread on my tire was severely uneven . On the front passenger the inside of the tire was bald but andit was unevenly bald. So it was bald but thinner on certain parts of the bald side lol and thicker on other areas of the bald side and we believe that was causing the bumping. I feel like im advertising for hair club for men.
Bought new tire they couldnt do the alignment there so im going to get it done when i return from my trip.
Your wheel is bent dude. It may look ok from the outside but it may be bent pretty bad on the opposite side(internal).
jahmezis45 (03-12-2013)
Wheel alignment and balance are two completely different things.
When you head your new tire installed they would've balanced that tire. The process involves rotating the wheel and tire at a extremely fast rate to check for any vibration or lack of balance. Weights or counterweights to be specific will be added to balance the tire/wheel combo.
Alignment has to do with your toe in/out your track. Essentially how straight your two tires are towards one another and to the surface that they're on.
If your wheel was bent you had a tire shop install a new tire to it and they couldn't tell find a new tire shop.
ahh i misread the balance questio. I went to pep boys they had the falken tires so i went with that. They had to have balanced the tire i mean thats standard. Im going back today though because im going to get three more wheels and find a shop in my area that is able to give an alignment. Ill report back
dmatthewman
09-30-2015 10:10 AM
