Shifting to Park --> Engine Shut Off
Occasionally when I rotate the gear selector from D to P, the engine will shut off as though I've pressed the Start/Stop button. It seems to only do this when I spin the selector quickly. When I consciously rotate it to the left slowly, the engine stays on and I then turn it off with the button.
It's not that BIG a deal, but there are times when I don't want the car to turn off (listening to the radio as an example).
Anyone else experienced this?
Mine does that also. It sometimes seems that it could be linked to the driver seatbelt. Unbuckle the beat while putting in park almost always results in the car performing a full shutdown
I have even had one time last fall that it shutdown at a stop sign in drive and when I let off the brake, it attempted to start for a very quick second then gave up and lit the dash up like a Christmas tree.
I had to use the start button, power it completely down and perform a restart process.
Seemed like it took forever (probably was only 30 seconds), and with traffic building behind me, it was embarrassing.
Received 3,208 Likes
That is unusual. I'm not judging, just curious as to your reasoning behind it.
Nup, I'm not being lazy, quite the opposite IMHO.
99.9% of auto trans drivers that I see sit at the traffic lights for minutes on end with the trans in D and their foot on the brake pedal.
On the other hand, if I judge that I will be stopped for more than say 30 seconds, I shift into N and apply the EPB. That way I can relax both legs/feet, no need to ensure I have a foot on the brake pedal. If I'm at or near the front of the queue then I ensure I have changed back into D before the lights go green, if I'm further back in the queue I simply watch for movement ahead of me before putting it back in D. I'm still concentrating but I believe I am more relaxed than those other 99.9% sitting there with their foot on the brake.
It also stems from 40 years of owning nothing but manual trans cars.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
I fully understand and support this reasoning. I have no problem putting my car in park while waiting at a light or in a drive-thru.
Perhaps its being half a world apart but that's not what riding the clutch is over here. I get the putting it in neutral part but not the using the parking brake in traffic thing. That's really strange to me! I just use the footbrake. But to each their own!
And a major reason I put the car in N and then engage the EPB is so I don't have to use my right (or left) foot on the brake pedal to stop the car from rolling. I can then relax and stretch, bend, whatever both legs.
Fair 'nuf if I'm stopped on a level bit of road, I could get away with not engaging the EPB, but as we know in hilly terrain it's easy to misjudge if the road is really level or not.
When driving a manual and stopping for any length of time over say 10 seconds, I always shift to neutral and release the clutch. Most times I also apply the handbrake. On the dozen or so manual cars I owned before my first Jag I never once had a single problem with the gearbox or the clutch. Once I bought my first Jag, which was the first auto trans car I had ever owned, I continued this practice - put car in N, apply EPB, relax.
We all have our little driving habits! I learned on and grew up driving and racing nothing but manual transmission cars and trucks for years. After getting my very first automatic car, people would make fun of me because I drove it with two feet lol. It just didn't feel right not using them both!!!! I'm long over it now but sure took some getting used to (both the automatic and the ribbing lol)
It would be helpful to know the year and model of your car, and whether it has the 'Eco' function.
On my '14 XFR-S, the 'Eco' function does exactly the same thing that you are describing, in addition to the usual 'Eco' operation at lights, in stop and go traffic etc. The difference between usual operation at a stop light, for example, is that it truly shuts off the car, including accessories like ventilation and the radio. It is intermittent because this function is only activated under certain conditions as determined by the ECU (for example, outside temperature, accessories running, level of charge). It is activated by firm brake pedal pressure, which is exactly what you apply when shifting the car into park.
The above may not apply to your situation, as it has nothing to do with how fast you turn the shift knob.
