Shifting to Park --> Engine Shut Off
It would be helpful to know the year and model of your car, and whether it has the 'Eco' function.
On my '14 XFR-S, the 'Eco' function does exactly the same thing that you are describing, in addition to the usual 'Eco' operation at lights, in stop and go traffic etc. The difference between usual operation at a stop light, for example, is that it truly shuts off the car, including accessories like ventilation and the radio. It is intermittent because this function is only activated under certain conditions as determined by the ECU (for example, outside temperature, accessories running, level of charge). It is activated by firm brake pedal pressure, which is exactly what you apply when shifting the car into park.
The above may not apply to your situation, as it has nothing to do with how fast you turn the shift knob.
I'll add now that it doesn't appear have to anything to do with seatbelts or speed of knob twist. Sometimes it happens, sometimes it doesn't. I generally don't bother to disable the Eco so it's very likely tied to this stupid technology.
Marquise Williams
01-18-2016 05:29 PM
theshortwhiteguy
01-10-2016 05:29 PM
NDW
12-31-2015 03:16 PM
