slight vibration steering wheel
Since a couple of months I've noticed a slight vibration in the steering Wheel. (the vibration increase when I go faster) -__-
I've took the car back to get the Wheels balanced, no change
I've told my tires dealer to check the rims for a bent or anything, but nothing
I even changed tires but no change, still feel that anoying vibration.
I'm starting to think it's because I changed the front upper control arm on only the right side, although I checked the left one and it was fine. now I'm like I will have to lift up the car again and check everythings out, like is it the lower control arm, the tie rod etc ??
Did anyone of you already experienced this kind of steering vibration ?
Thanks but it's not my brake pad or rotors I changed them 6 mounth ago and cope them from the jag dealer ! I found my problem is a wheel bearing
FS[SouthernMidWest]: WANTED: XK8 J-Gate Shift Selector Face
tr8bofin
05-01-2016 07:30 PM
