Slowly upgrading base audio, info required
Hi, had my XF S 2011 pre facelift since July and love it, apart from one thing - the stereo. I have no amp and one speaker and tweeter in each door, nothing else.
Recently bought the B & W speakers for the front doors to start of with ( at that point i thought i had amp and three basic speakers in the front doors ).
I've fitted the larger speaker, not really noticed much difference which i guess is down to the standard head unit not being good or powerful enough. Need to cut out the holes to fit the smaller speakers which ill do this weekend.
My question is i found these 2 threads -
https://www.jaguarforums.com/forum/x...-audio-178264/
https://www.jaguarforums.com/forum/x...ispreloading=1
Which have been very helpful. What id like to know, is the amp and head unit which Cambo suggests the only combination to get? For example i probably wouldn't get the Jag subwoofer that goes in the spare wheel well. Maybe go for something like an active underseat sub. I think this would get its signal from the rear speakers ?
I may not even bother with the rear surround speakers in the parcel shelf, not sure yet. Im really looking for a decent improvement on whats already there. If i get the head unit that Cambo suggests does it matter what amp i get in regards to power output? Are the B & W and the Meridian amps the same or interchangeable ?
Finally I'm in then UK so would need someone to configure the CCF for me, thanks for help and advice.
Where I'm at so far
Where I'm at so far
Thanks, appreciate that. So many head units there I have no idea which one I need ? The part numbers on there are different to the part numbers on eBay for example.
I think I need a 6 disc head unit and the matching Premium sound amp. So hard to find all the info. Someone must have done before ?
https://www.ebay.co.uk/itm/303952484...AAAOSwkZ5gbzAV
Is there a way to find out how many channels and power output these are ? thanks
https://www.ebay.co.uk/itm/133682224...MAAOSwqTVgQCDy
https://www.ebay.co.uk/itm/353777554...p-shop&mkevt=1
https://www.ebay.co.uk/itm/265236877...p-shop&mkevt=1
AMP 8 channel
https://www.ebay.co.uk/itm/114291557...=&toolid=10050
CD UNIT from the same car
https://www.ebay.co.uk/itm/114270562...MAAOSwt4he8K1x
darkeyesoflondon (11-29-2021)
Thank you so much. My search skills are obviously rubbish lol. Ive ordered those, hopefully its straight plug and play with no CCF files needing adjusting. My car has a spare wheel so next step will be deciding whether to go for the Jag sub or an active powered one.
AMP 8 channel
darkeyesoflondon (11-30-2021)
The last two are fairly obvious you'd think but again, this is for my XK
These are the settings to change in the CCF from Base to Premium;
RADIO_AMP_AND_SPEAKER_SYSTEM
Change from 0x02 Audio 'Base Performance' 4*25W, 6 speakers
To 0x04 Audio 'Premium Sound' 4*70W, 12 speakers
CENTRE_SPEAKER_DASHBOARD
Change from Without center speaker
To Small center speaker
SUBWOOFER
Change from Without subwoofer
To Subwoofer
SUBWOOFER
To Subwoofer
Ok, i wont be using the centre speaker. I thought this amp didnt have that output ?
SUBWOOFER
To Subwoofer
SUBWOOFER
To Subwoofer
Yes. CCF and firmware are two different things. CCF tells your car what functionality it has and firmware tells the module what functionality it has. It's good that they're from the same car so now you won't have to flash the correct firmware onto the amplifier. But you still need to tell the car it now has the new functionality, hence editing the CCF.
Thanks, so my next problem is finding someone who can do this for me. Ill probably wait till i get the subwoofer.
Yes I would wait to install everything before moving forward with finding someone with CCF. An indy should be able to do this for you. The selections in CCF are limited. Good luck!
Sean W's CCF parameters are correct for the pre-facelift X250. The facelift has a different B&W sound system.
The following 2 users liked this post by MoJo88:
darkeyesoflondon (11-30-2021),
Sean W (11-29-2021)
Really appreciate your offer. The seller is going to be in my city next week and offered to do the CCFs for me.
Thank you for the offer of help
bart_redline99
Audio/Visual Electronics
04-23-2012 05:07 PM
