Is SLX professional oil necessary and where to get?
Old 10-26-2011, 08:27 AM
jlindy's Avatar
I bought 2 Quarts of the SLX Professional here in Denver when visiting for work.
So if my reading (when it's cold) says add 0.5 L or sometimes add 1.0 liter, I will be fine to drive it home from the airport tonight and retest when it is hot to see if I can get a more accurate reading?
Old 10-26-2011, 08:51 AM
Originally Posted by Blackcoog
That might be true for the 5.0L but he has a 4.2L which is probably where his numbers come from.
DUH! 2009........4.2L! That was stupid............
Thanks for keeping me honest, Blackcoog, I spaced that one.
Recap:
5.0L Castrol SLX OE Professional 5W20 Capacity 7.25L (Basically 8 Qts.)
4.2L 5W30 Conventional Oil (Synthetic recommended) Capacity 6.0L (Roughly 6.5 Qts.)
OP was inquiring about the SLX oil, must be a 5.0L engine.
Cheers,
Old 10-26-2011, 08:56 AM
I'd be down with that......Just don't drive like Dario on the way!
Cheers,
Old 10-26-2011, 07:50 PM
jlindy's Avatar
Ok did that. Drive home from airport nice and slow and waited 20 minutes or so and still said add 1.0 L so I added just under one Q and now says level ok. Thanks.
Old 10-27-2011, 08:56 AM
jagular's Avatar
Regardless of the exact total capacity of the sump my main point was that it is a lot of oil. Emphasizing that the engine is designed to run all day every day with the oil at the low point it is unnecessary to worry about th exact oil level as long as it is above the low and not above the high point. Too much oil is worse than half a quart low.
Old 11-02-2017, 03:10 AM
dpresent's Avatar
My 2013 XF 3.0 (V6 SC) calls for 7.25L. My mechanic has a tool that can read the oil level in the sump. He insisted on reading it cold, however. If he adds oil when cold and gets a reading of 7.2L, what is the likelihood that he has overfilled the sump?
Old 11-02-2017, 07:18 AM
JagV8's Avatar
Received 4,538 Likes on 3,947 Posts
A 6 year old thread. Haven't you asked about oil enough????
Swimref (11-02-2017)
kthrash
02-25-2019 10:20 AM
JCam
10-23-2016 08:27 PM
ahunt4
09-25-2015 03:43 AM
Tim Goz
09-17-2015 09:11 AM
teacoff
09-10-2015 08:25 AM
Quick Reply: Is SLX professional oil necessary and where to get?
