For those who want much better trunk/boot lighting but are put off by splicing wires: 2pcs HID White 24COB LED Panel Light for Car Interior Door Trunk Map Dome | eBay
I fitted one of these a few months ago, works really well, plug & play with no splicing, just peel & stick to the exposed metal near the existing light, and as you can see they are cheap as chips.
Yep, you can forgo the splicing if you just want to use one light with the bulb adaptor and eliminate the stock bulb. I actually soldered the 2 LED banks together and spliced in them in to keep the stock bulb which I had already converted to LED.
