smart key fob issue
Replaced key fob battery today due to "low battery smart key warning".
now fob will not work message "can't find smart key".
I can start the car through fob slot.
Yes battery has been checked as good contacts appear fine could it have "unpaired"?
Any assistance appreciated. 2012 XF
As far as I know, the car cannot unlearn the key code without being programmed to delete it. As for the fob it sounds like it may be defective. Possibly check to see if the contacts are clean or if there is any film on the battery surface. The area where the battery makes contact inside the fob could have something or some corrosion on it. This is assuming that you installed the battery correctly. If all else fails, you can take it to a locksmith who has smart key capability. He can test the fob to see if it is transmitting properly.
Jag is at dealer since 8am. As of now they have checked the smart key and appears functional however the car is still not recognizing it..Evidently the issue is more complicated...Thank god for the warranty And a loaner. The car does start when fob is placed in ignition slot
I generally based on experience find their diagnostic abilities to be sub par.
I think that somebody is telling you a story. You can program a previously programmed smart key to your car. A good locksmith with smart key programming capabilities will tell you the same thing. And you can program up to five key fobs. And you can delete just as easy as you can add keys.
I will however suggest they perform an exorcism on the remote.
You guys are too funny.....divorced huh?
I can't logically see how it would be hooked to a previous vehicle permanently until divorced since it is only a transmitter. Perhaps, the Jag dealer does not want any liability for having two vehicles potentially able to be started with the same key. But each key is pretty unique. So what would be the chances of two vehicles in the same area having the same key programmed to that particular remote?
Wolfy
05-28-2024 08:06 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
