Solving the horrible brake dust on the rear pads.
Our 13 XF AWD suffers from horrible dusting on the rear wheels (to the point that I had it looked at thinking the ebrake was sticking a bit but Jag claims it is "normal"). I have had cars with race pads that dust less. In a couple hundred miles the rear wheels are black, the fronts are just lightly covered. The pads are Jaguar OEM pads Have been a fan of Akabono for the other two cars for their performance and low visable dusting. Anybody go with Akebono pads on theirs and if so how were your results? No loss in braking or feel? Dusting? etc. Also, anything special about replacing the rear pads on the XF? I'm guessing I need a Ford wind cube tool right?
Definitely go ceramic. I posted somewhere on here about ceramic pads. I think Akebono has the rear, but they definitely don't have the front. I used some other brand that seems to work just as well.
That dust you see on your wheels is not just brake pad material, it's also the rotors. So the sooner you get rid of the crappy stock pads, the less you will be spending on rotors.
Since I switched to ceramic pads, the pads are lasting much, much longer, and there's no wear on the rotors.
Don't get the EBC ceramic pads though. They are a joke. Lots of dust and they wear out fast (which goes hand in hand).
And yes you need to wind in the rear calipers with a special tool.
TreVoRTasmin (08-01-2017)
I have never been a fan of EBC for much of anything. OK for racing applications but even then there are better. There is a listing for the fronts (at least for the 3.0 via Akebono if I read it right when I did a search for the rears.
On the RWD XF cars the rear pads go quickly because the traction control modulates the rear brakes and burns through the pads. Usually the rears get replaced before the fronts. You'd think the AWD setup would be different though since traction wouldn't be much of an issue. I switched to ceramics because I couldn't deal with all the dust. Find a good ceramic pad.
I replaced my rear pads with Akebono and they produce no dust at all. They don't make pads for the front on my car, so I got Powerstop Eolution Clean Ride. Those are also very dust-free. No issues since the installation. BTW, Tire Rack claims Centric Posi-Quiet is as dust-free as Akebono. Make sure you buy new sensors (front and rr are not the same). Pex brand sensor is the Jaguar OEM sensor for around $30 instead of $90+ for the Jaguar branded version.
Received 3,231 Likes
He's talking about the pad wear sensors.
There are two of them, one on the inner pad of the front left brakes and one on the inner pad of the rear right brakes. They don't reset, once they trigger they are toast and need to be replaced, as they work by wearing through a contact once the brake pad wears down to around 4 mm thick. Even if not triggered/worn through they are a pig to remove and relocate on new pads as the end clips go brittle with age and often break off as you try to refit them, so best to get new ones.
The other solution is to disable them, by cutting the cable and joining the two wires together. If you simply remove the sensor altogether you will get constant error messages, but by leaving it plugged in (not to the brake pad, but the other end up in the wheel well) with the wires joined the system thinks it's all A OK and you won't get any messages. Of course if you do this you will no longer have working sensors and you will need to manually check for pad wear, but that's easy enough to do and you should do so every now and then even if you still have working sensors as they are not infallible.
TreVoRTasmin (08-03-2017)
I'm talking about the brake pad wear sensors.
There are two of them (one front left and one right rear) and they are small pieces of plastic that break easily. I replaced the front pads myself to eliminate the brake dust and the sensor broke when I was removing it. It had not yet begun to show a low-pad warning. If it is not yet illuminating and you're very lucky, you may be able to re-use the sensor, but sometimes they break while you replace the brake pad.
Are you talking about OZXFR and me? We both took the time to provide you with useful tips and accurate information, and you return the favor by insulting us?
My wife's hasn't shown a code as I'm replacing because of the horrible dusting the rears are producing. Wheel is black in 100 miles and I mean BLACK! Jag says they aren't sticking so their crappy pads with 60% life are going in the trash.
Two thoughts. You can buy an aftermarket sensor for a fraction of the price of the OEM ones.
But if you still don't want it, it's a closed loop of wire and as the pad wars thin the wire is broken and sends an error code. So just cut off the old sensor, short across the wire and tie it back up in the wheel well. And it should never bother you again
Ceramic pads like the Akebonos give you much much less wear on the rotors.
Use common sense. If the Akebono's give no dust, but they grind down the rotors, where is that rotor dust going?
It's not that hard people.
Internet myth. Completely bad information being spread again, this time by "Trevor."
Internet myth? If Ielieved what I read on the internet, I would own a Lotus not a hairy chested Tivver LOL, plenty experience with using ceramics for years. As for common sense, Akebono's and other ceramics give lots of dust, it is simply not as visable as semi metallic dust from standard pads. It isn't hard, experience is the key and I and many others see increased wear due to ceramic pads. They eat my Tiger rotors insanely quick but it is a trade off I'm happy with so the wheels don't turn into your average front rims on a Mercedes.
