some new pics...
Actually, I didn't think I would like it when it was first beginning, but from the pictures, especially no.2, I'll give it a thumbs up. I would not do mine this way, there's not enough rubber between the wheel and the pavement, but the black is good. So, from initially giving it a -3, I will revise to a + 7. This is based on what I like in a vehicle only.
I think the car has a very cohesive look to it. The size of the wheels/tires seems appropriate for the look you may be trying to achieve. Very nicely done!
I removed my rear license plate frame this weekend following the suggestion of one of the members here. Have you thought about removing the frame altogether?
Wheels are Vossen CV3's and the ride is a bit stiffer and bumpier especially with the springs, but its tolerable, plus I dont drive the car a lot. I put about 400 miles on it so far and I have had the car since May.
I want to say that the combination of the wider wheel, stiffer sidewall on the tire and the lowering springs makes the car feel a bit stiffer than the dynamic mode when I am in regular mode. Now dynamic mode basically eliminates body roll, which is pretty remarkable for a car this heavy. I am considering rolling the fenders and fitting wider rear tires when the time comes to replace my P Zero Neros.
jaguny (09-12-2012)
Mr_Ke1th
04-20-2015 02:20 AM
