Spongy brake pedal.
It does stop fine but i gotta, press the pedal a bit more than normal, it's gets worse when the brakes get hot after driving a lot, yes it's spongy.
I wouldn't have thought it would be braking properly if your brake pedal slowly pushes to the floor.. If this is happening & you can't find a leak the chances are good you've either got air in the system or a duff master cylinder. If you can't bleed any air out (or nothing changes after bleeding) then it's likely the master cylinder. It sounds like you're driving around with faulty brakes & if it is the master cylinder, at some point it's going to fail badly & you won't have any brakes (ask me how I know).
But i haven't been able to do any conclusive testing, with the car cold turned off without servo assistance, the pedal is hard and doesn't sink, so I can't really says 100% sure it's the MC. I have bleed it 2 times, no air comes out.
Anyway the car is 11 years old a New master cylinder won't hurt. But I'm not sure if it will cure the problem.
I don't drive the car everyday barely once a month, i use my wife's bmw, and won't be driving it untill I sort this out.
I took the car out the other day, for some intense acceleration and very aggressive braking, the brakes feel very good after that, apparently it solved the problem , I'm not sure how, but the pedal feels great now.
So I'll keep the new MC i case the pedal starts acting up again.
al_roethlisberger
08-20-2015 06:18 AM
DB6
06-21-2011 11:21 AM
