Squeaky Dash - 2012 XF
Over the last couple of hundred miles, the dash has started making squeaky noises. It sounds just like dry leather/vinyl rubbing against dry glass. I know squeaks and rattles are common as a car gets older, but this has really been getting on my nerve. I cannot take quiet drives anymore and listen to the engine, I have to have the radio on to over power the squeaky noises.
The noise is coming from across the entire dashboard where it meets the windshield. Has anyone encountered anything similar? If so, any resolutions to the issue? My car is the Portfolio model, not sure if it makes a difference.
Received 3,218 Likes
Jaaaggg (02-15-2016)
I had a very similar issue. Eventually worked out that it is the outer rubber trim along the bottom of the windscreen. On mine there is a thick rubber trim about an inch high along the bottom of the windscreen outside. I ran baby wipes underneath the rubber using my finger to get all the grime and dirt out. Then I used a little sil-glide on it. It has been great since then
It still comes back when it's very cold - but nothing like as bad as it used to be
I'll use this to wipe:
