Squeaky suspension
Depends on which rear bushing! But most of them can be replaced. Consider Powerflex bushings if you're going to the effort of replacing them. The service manual mentions lots of different special tools for the bushings around the car but most of the time these just refer to the different sized inserts to press them out - so long as you have access to a hydraulic press (you'll be needing one) with a decent range of insert sizes you should be fine.
There are a few bushes on the back end and would also recommend powerflex bushes as they have a lifetime guarantee
Patrick Kelly
05-19-2016 12:04 PM
RRT
02-07-2012 06:01 AM
