Startup sequence delay on cold starts
So this winter I've been noticing a pretty big lag between when the car is fired up and when the vents open/nav screen boots up. Probably about a 10 second or so delay. On warm starts the response is pretty much immediate. Has anyone ever experienced this before? Thanks.
btw its a 2009 Prem Lux XF. 128k km on the clock.
I turned on the car in accessory mode this morning (didn't start it) and I was immediately greeted with a low battery warning on the nav screen. I'm not experiencing any random glitches so once the car is running the power supply seems to be consistent.
Does this look like its a battery on the way out? The battery is 2.25 years old. Ultra flat panel AGM. I've also been keeping my 2 dashcams plugged in the 12v outlet at all times so perhaps this could be draining the battery.
Once the car is running the alternator helps to stabilize power
Dashcams may be slowly draining power (aren't they in a switch power source so they go off when car is off?) and combined with the cold that's showing weak battery. Or the battery itself might be failing. Given its over 2 years and showing signs of age I'd suggest replacement so you don't get caught somewhere...
nasa25 (02-28-2016)
The 12 volt power outlet (cigarette lighter socket) as I have been told by an expert, is only active for 30 minutes once the car is off and shut up.
nasa25 (02-28-2016)
If you are talking about the Battery Monitor system...Don't worry about it..My JAG Tech friend, also a member of this forum now (Brian11) ..Told me yesterday that the Battery Monitor system doesn't need recalibrating. The factory school he went to told him that..The system will recalibrate on it's own over a few starts and stops..
nasa25 (02-28-2016)
It prompts you to pull the e-brake up after a battery reset. That is all you have to do to reset it. It will automatically adjust after you pull it up.
As for the windows this was pulled from a document someone wrote up a while ago:
Your switch has 5 positions. We'll call them:
- "-2" which is the switch all the way down for automatic down
- "-1" which is the switch slightly down for bringing the window down manually
- "0" which is the switch just sitting on its normal position
- "1" which is the switch slightly up for bringing the window up manually
- "2" which is the switch all the way up for automatic up
- Shut the radio off and other source of noises, you are going to be looking for a little "click"
- Hold the switch of the window you wish to re-teach the limits in position "-1". Even after the window is all the way down, keep holding it and listen for a little click. When you hear it go to the next step.
- Hold the switch on position "1". Again, even after the window is all the way up keep holding it and listen for a "click".
- That is it! Repeat for all windows and you are all set!
