steering column memory sometimes forgets to return to preset?
I have a '13 XFR, and I have my personal seating and steering column positions saved to preset 1. When I exit the car, the steering column moves up as expected. Most of the time, when I get back in and start the car, the steering column returns to my preset 1 position. Sometimes however, the steering column stays up (even though I have not touched the steering column position setting or seat setting). When this occurs, even if I press and hold the preset 1 button, the steering column doesn't move. If I manually move the steering column for a split second, then press and hold preset 1, the steering column then returns to the correct position. Has anyone experienced this issue?
And yes, I have my steering column setting set to Auto (not manual).
Any advice would be greatly appreciated.
Check if this happens only when your door is open when you start your car.
I have had this happen on my 2012 XFR and only if the door was open when I started the car it will not go to its preset position.
In my case, when I stop somewhere and restart it works fine, assuming my door is closed...
Or I quickly press preset 2 then press preset 1, and it will go back to where the preset mandates.
