Steering Column Snapping
OK....I checked the archives for this problem but nothing. When the column moves up out of the way after shutting the engine off, there is a loud snap before the column stops. It works fine in all other modes with no other noises. Is this a grease problem or a motor gear problem or the "famous bent washer" problem ? Oh and this is on a 09 XFSC .
I thought that it might be the shroud so I used a couple of window tint samples (that are very smooth and thin ) and placed them in different places between the shroud (and the steering column) and the weighted spacer on top. This was done on the top of the column since the stiff "plastic spacer" was spring loaded to fit on top of the shroud regardless of it's vertical position. I simply slipped the film samples between the spacer and the shroud especially around the end corners.....and voila, no more snapping. The downward turn of the top spacer at the corners was too tight against the shroud.....with the film insert, the column and the shroud just slides past the plastic spacer. You can not see this fix because of the smokey color of the film but I would like to have a more permanent fix. Suggestions?
Woznaldo
09-26-2015 11:02 AM
