Sub woofer for XF
Old 04-20-2018, 03:31 PM
Tunooo1965's Avatar
Default Sub woofer for XF
Hello, I want to add a 1000watts sub to my 2014 XF. But Jaguar dealer told me that this may cause problem to my car electrical system since I am adding 1000 watts amp and which will use Battery power. But I see so many people added after market sub. Please advise what should I do.
Old 04-20-2018, 08:45 PM
BlckCat's Avatar
I have a 500 W RMS amp and it is perfect. I had the factory sub so the install was very easy, everything is in the trunk. I made a custom box that fits under the floor but I had to get rid of the spare tire. There are a few threads on subs, here are a couple with pictures of what others have done.
https://www.jaguarforums.com/forum/xf-xfr-x250-44/subwoofer-spare-tire-well-105954/
https://www.jaguarforums.com/forum/xf-xfr-x250-44/amplifier-subwoofer-install-help-111669/
Here's mine.
Tunooo1965 (04-20-2018)
Old 04-20-2018, 10:22 PM
Tunooo1965's Avatar
Thank you. Did you upgrade the front and rear speakers. I wish to change the speakers too. Let me know what you did. Thanks again.
Old 04-21-2018, 08:08 PM
BlckCat's Avatar
No speaker changes other than the sub. I have the mid-grade Meridian system and with the aftermarket sub/amp it is the best sound i've ever heard in a car. The top of the line Meridian is great but the bigger sub makes a big difference.
Old 04-23-2018, 01:57 PM
2010 Kyanite XFR's Avatar
I had a 900w class AB amp initially and have since replaced it with a 1200w class D amp. No electrical issues. But I do have an Interstate AGM battery that might help. I also had a 1500w class D amp and had no issues.
One thing I recently did is buy a salvaged trunk floor, cut a hole in it and vented my sub directly to the trunk. Put my cast aluminum grill on the top side. It sounds better on higher bass notes, but doesn't hurt on lower notes. Much punchier sound.
skymark
02-11-2024 07:00 AM
Victor Marquez
24
05-29-2021 07:47 PM
sanchez
XJ40 ( XJ81 )
04-19-2018 05:35 AM
davesjag
04-01-2018 06:37 AM
JackOfAll
03-19-2018 04:07 PM
Quick Reply: Sub woofer for XF
