Supercharger Coolant Pump Replaced
Finally got my supercharger coolant pump replaced after over a year. The way you'll know if yours has an issue is if are pushing it REALLY hard, as in full throttle quarter mile runs back to back, it will give you a restricted performance situation and it throws a code (P2601).
From experience, don't check the code if this happens because for some reason it clears it. Took me two times of taking it in and no code present to learn this. If it happens to you take it to the dealer and tell them what happened and what to fix. Otherwise, the car was fine so no other way to tell.
The tech said it's a separate system running off of the same tank and the way the code is tripped is if the air temp coming out is out of line for what is coming in.
When I get my TCP intake installed I'm going to get another dyno run done. I'm wondering if the pump not working is why it seemed to heat soak worse and would dump more fuel on the second run of two. The first run of my last session had the tires spin on the drum. On the second it put up the numbers in my signature. So always felt cheated. Looking for something over 500 for sure this time. I think Brutal got in my head a long time ago and even though it costs $100, I feel like I need to measure the change.
The following 3 users liked this post by 2010 Kyanite XFR:
