Supercharger Oil Drain and Fill???
"Do you think there could be any benefit to tilting the car in any direction?
I could use ramps and/or the hoist to lift the front or back, or even lift one side.
The hole on my blower seems to be offset towards the passenger side.
plan to have the car in the same position for all four changes so the test is consistent."
Really depends on your extraction pipe flexibility is getting the access to the bottom of the bearing housing.
See what adjusting, repositioning the extraction pipe makes first, and then progress to the repositioning of the Car. Slope, Tilt, Front High or Low to increase the quantity extracted and the end results.
1 oz= 28.4ml
3 oz= 85.2ml
1 oz= 28.4ml
3 oz= 85.2ml
Thanks again for the tips and ideas, I'll let you know the results
bydand (06-20-2024)
Here is a chart from Eaton on oil fill capacity.
Does not mention the Jaguar R1320 specifically?
Oil Capacity
Oil Capacity
Oil Capacity
Oil Capacity
These below are TVS R 4 lobes rotor.
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x321/screenshot_2024_06_20_at_14_46_30_abf9212579f23c5fced4f9563bab668f2550e94d.png)
4.2 fl oz R1320 and 5.1 fl oz R1900
These below are TVS 3 lobe rotors.
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x217/screenshot_2024_06_20_at_14_52_32_7b6f927c2200e0aee977dc103c9c9f35124bfa28.png)
5.1fl oz TVS 1900
It would make sense the smaller Supercharger TVS 1320 has less oil, 4.2fl oz. (or 4.1fl oz) as the TVS 1900 has 5.1fl oz.
Even thou a lot of people fill the TVS 1320 with 5.1fl oz.
The difference between the TVS and the R is the number of lobes.
https://www.eaton.com/us/en-us/produ...-overview.html
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1047/screenshot_2024_06_20_at_15_20_22_6a1775e126912fda56c1be8e51ae7cd0676eb8fe.png)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1638x880/screenshot_2024_06_20_at_06_29_52_0eeddba1aff6c2bb93a583d036c062eaa7e4fb7c.png)
TVS R1900
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1608x886/screenshot_2024_06_20_at_06_31_15_f6527eafca5c618c67b7e128e41f77c3efed6564.png)
TVS R1320
US fl oz= ml.
4.2fl oz = 124.2ml
5.1fl oz = 150.83ml
So if loss rate is 125-87ml = 38ml over 65k km = 5.85ml/10k km.
So what is the effect of adding 150ml of oil to the TVS 1320?
None so far as I know!, but gives you 25ml more oil and 40.2K km before reaching 87ml in the bearing housing. If the seepage loss remains the same.
dangoesfast (06-21-2024)
