Supercharger whine or lack there of
The only way to get the whine is with a new intake tract. You can add a hot air intake and you will hear lots of whine, but it will cost you a tad bit of power. I went through this many times already and have just left it alone as the stock MAFs run out of spec. I added a custom twin cold intake and the whine was great but at idle the car would stall after a hard or moderate speed was just done. Sucked stalling at a stop sign randomly.
You could cut them off flush and then get a silicone coupler in black and cut it and then wrap it over the hole and glue it in place. The finish will look like stock and if you use an epoxy it will hold forever.
Not sure how much whine deleting those resonators will give but It is worth a shot for at least some sound.
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
